Idle problems after rebuild
Old Jul 25, 2001 | 08:07 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I just rebuilt a holley 500cfm 2 barrel. Now when I start it I have to choke it, but as soon as it starts, I have to open the choke back up or it dies. I never had this problem before the rebuild, I would pump it twice and hit the key. Any ideas on what I need to do?
Later
John
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Bfg DR's.
Check out my birds new home.
Best et 8.21 @84mph in the 1/8th
Old Jul 26, 2001 | 07:30 AM
Damon's Avatar
If you're talking about a manual choke Holley and starting a COLD engine that's normal.
If you're talking about an electric choke carb that should be fully automatic then you probably forgot to connect the vacuum line to the little vacuum diaphragm on the pass. side of the carb to the correct port. It requires full manifold vacuum at all times to do it's job.
Or, if you forgot to connect it's linkage to the choke linkage properly or messed with it's adjustement it could also cause those kind of problems. It's job is to pop the choke plate slightly open immediately after startup to prevent the kind of problems you are describing.
Old Jul 26, 2001 | 03:13 PM
spud's Avatar
Engine: 400 & 355
Damon
Its a manual choke, and cold engine. None of my engines have ever had this problem before. I'll try adjusting the linkage then.
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
hokis
Aug 9, 2015 03:57 PM
