Choke Heater Relay Location
Old Aug 21, 2001 | 12:22 PM
quattroboy's Avatar
Aaaaargh, were is the damm thing? I can find the fuse but where is the relay? On the Carb? (Rochester Q Jet 86 Iroc Z 5.0 LG4)
On the firewall? What does it look like, how many connections. Any Part Number so I can just order one and figure it out from there?
Any info gratefully received.
Frustrated quattro freak in England with a warming sensation for Iroc Z's!! (Should have gone for a fuel injection model?)
Old Aug 21, 2001 | 04:34 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Let me try to help ya on this one-the ALDL connector is behind a little removable panel up above your leg when you're seated in the driver's seat (not sure which leg it's above on your car since you're in England, but it's a good reference point). It's got twelve pin-sockets, probably only about six of them are loaded. Anyway, this thing is mounted on the front of a metal tray that when taken down from under the dash, will be holding a bunch of relays & stuff. C-H relay should be the green one. You'll have to remove the trim panel above your feet to bring down this convenience tray. Hope this helps you.
D.R. Stevens
1984 Trans Am 305HO L69
all the usual external/free mods, original engine
1991 Firebird 305 L03
bone-dead-slow-stock
Old Oct 19, 2002 | 05:56 PM
Bigbird's Avatar
Choke heater relay location
Question? I have an 87 T/A. Is there another location for the choke heater relay. I looked in the convienence center. There is a place for it, but no relay, or wiring to the location..thanks.
Old Jan 26, 2023 | 03:36 PM
Vgibson's Avatar
Re: Choke Heater Relay Location
you probably found it, but the other place to look for the relay box in 3rd gens is on the passenger side, not driver's side. I tried looking on the pass side for mine, but it's actually in the other location. I hope this info helps others.! I need to find out how many signal ones there are. Some models have 3. One for emergency and 2 signal ones. One for front, the other for the back. Great. OK. Cheers!
85TransAmDude
Jul 6, 2011 12:14 PM
Jacob&His`83
Carburetors
May 21, 2007 11:46 PM
black84-6spdz28
Mar 20, 2003 10:20 AM
HamsterOnaMission
Carburetors
Mar 10, 2002 04:17 PM
quattroboy
Carburetors
Aug 21, 2001 11:07 AM
