Still frustrated about horn relay
Old Mar 4, 2007 | 06:09 AM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Alright...I have a pic here and im wondering if any of these is the horn relay?...i have the new relay so i know what it looks like...it looks identical to the blue and green ones except the new relay i bought is black...are any of these the relay?...thanks
Old Jun 2, 2007 | 02:18 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Re: Still frustrated about horn relay
its the wh square one in the middle, i bought a new one to and it was black.
Old Jun 2, 2007 | 06:17 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
what's the blue thing? I swapped interior harnesses today and had to swap that over.
Old Jun 3, 2007 | 12:03 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
The blue item at the right side is the AUDIO ALARM ASSEMBLY. The buzzer that sounds for seat belt not fasened, key in ignition switch and driver's door open, headlights on and driver's door open, etc.
The white relay in the middle top is the HORN RELAY. The green realy in the middle bottom is the CHOKE RELAY or CHOKE HEATER RELAY (if you have a carbed engine) It serves the same function but my service manaul refers to it both ways. The circular relay at the top left is the HAZZARD FLASHER.
Dave
Old Jul 2, 2011 | 02:46 PM
Timaaay's Avatar
Car: 85 Firebird Custom
Engine: 1973 400 CID worked
Transmission: TH 400 worked
I can't see the pic. Can someone tell me where these relays are located? I'm trying to find the horn relay. Is it under the dash or under the hood?
Old Jul 2, 2011 | 03:38 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
this thread is from 2007. thats why you cant se the pic, and you probably wont get a reply from the OP. id suggest making your own thread with your specific issue and as much info as you can put in.
Old Jul 3, 2011 | 08:55 AM
The Relay is located under the dash, il re-post the origional pic but this thread is 4 years old I cant remember which one is the horn relay lol I believe its the green one but someone can correct me on that if I am wrong.
Old Jul 6, 2011 | 12:14 PM
See my comments in Message 4 above. The White relay is the horn relay.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
