Car won’t fire up.
Old Jul 16, 2022 | 06:25 PM
Help me please!'s Avatar
Car: 1986 firebird tran am
Engine: V8
Transmission: Automatic
Axle/Gears: Rear, 6 speed
Car won’t fire up.
So basically I have a firebird trans am 1986 v8 fuel injected. I put a lot of work into and still doesn’t stay on. I need help figuring it out. Basically I changed the fuel pump, fuel filter, clean the fuel lines, new coil, spark plug wires, spark plugs, new ignition switch, relays. New maf sensor, tps. New rebuilt alternator new battery. The car use to crank and stay on and idle randomly. Then suddenly it won’t fire up. Cranks up and just won’t stay on yet it seems to cut on then off. Idk if it’s the starter it has failed before. Can it be its draining power and causing a start issue. I also feel like I messed up while changing my valve covers I felt a rocker arm lose so I tighten it a little idk if that through the whole car off. Any ideas???
Old Jul 16, 2022 | 06:50 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Car won’t fire up.
Set valve lash properly and do basic troubleshooting.
what are you missing , good compression, fuel , spark, correct timing ?
why throw all the parts at it has it sat for along time ?
Old Jul 16, 2022 | 07:26 PM
Engine: V8
I don’t know if it’s the timing the car starts up sometimes like really nice. Also yes the car has sat for a long long while. How would this valve lash be done ? Doubt it’s the fuel it use to rev up super nice also when given gas
Old Jul 16, 2022 | 07:41 PM
Engine: Lb9
Transmission: M20
http://www.73-87.com/7387garage/drivetrain/valvlash.htm
google is a great resource
Old Jul 16, 2022 | 08:44 PM
Engine: V8
i might do this.
yet how can I tell which are cylinder valves??? I’m guessing cylinder valve is the exhaust?? and intake valves is intake valves. Think you can give me a diagram? Like idk which are which. I have notes I’m taking and from a “Pontiac Haynes book” says at 0 lash on piston 1 I can adjust 1,2,5,7 intake valves. Then 1,3,4,8 exhaust valves. I just don’t understand which is which like I know each cylinder has two rockers so for example (1) piston which rocker is the exhaust and which is the intake?
Old Jul 16, 2022 | 08:55 PM
Engine: Lb9
Transmission: M20
Pull the vc pretty obvious which is inTake and exhaust by looking at exhaust ports and valve orientation.
Old Jul 16, 2022 | 09:08 PM
Engine: V8
this ain’t my engine just as example. So I’m looking at the pictures and it looks like the first rocker is the intake and the second one next to it is the exhaust is this correct that means on my firebird it should be in that same order right ? I doubt it would be flip or would it doubt it….??! Anyways can anyone confirm. Also what you mean “pv”
Old Jul 16, 2022 | 09:17 PM
Engine: Lb9
Transmission: M20
Might look at a sbc head image it’s different
Old Jul 17, 2022 | 07:30 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Originally Posted by Help me please!
can anyone confirm.
This is a Gen 1 sbc cylinder head; they are all identical in regards to valve-port orientation:
Ex-In-In-Ex-Ex-In-In-Ex
I don't recommend using a service manual from a different manufacturer. Find one on ebay for your specific 3rd gen. Additionally, Haynes or any other non-Helms manuals are neither complete nor accurate in their content.
Old Feb 21, 2023 | 04:12 AM
ermandadana's Avatar
GeneralIesrussi
Jan 25, 2018 12:39 AM
KingsHustleLA
Oct 16, 2013 07:38 AM
AirmanJordan
Mar 16, 2009 09:02 PM
rjpbboi
Feb 12, 2006 09:01 PM
PONTIAC86style
Jul 7, 2003 10:04 PM
