Sick of falling on my face
I have a zz430 clone with a holley 750 Vacumm secondary. The carb falls on its face when I drop my foot. I think its not getting enough fuel. it has a 30cc pump a black cam for the pump, and a 25 shooter. The secondaries have the lightest spring in them.
1. What should I change first the cam, the shooter or go to a 50 cc pump?
2. When I pulled the shooter tonight it was dark I just want to make sure I didnt loose anything. I recoverd the screw the shooter, and 2 gaskets one above the screw and one below. Is there any thing else I might have lost?
Transmission: 4L80E/4L80E
1. The problem isn't your accelerator pump, it's your secondary spring. Put progressively heavier ones in there until the bog goes away.
2. You got everything.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited September 05, 2001).]
Car: 82 camaro SC
To make things easier when tuning, put the tightest spring in the vacuum secondaries. Then tune the primaries(shooters, pump cams, jets). Then install the lightest spring and work your way up.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
Thanks for the Info guys. I guess I better get quick change spring kit on the way. I thought I would loose some performance if the secondaries didnt open up rignt away. I am looking forward to building the the Wide band Airfuel meter that is posted on Diy-efi. Thanks Again
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Also I would recommend swithcing out the metering plate for a metering block. (although this has nothing to do with your stumble it will allow you to better tune your holley.
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
Linson
Oct 1, 2015 09:50 PM
3.8TransAM
Oct 1, 2015 07:47 PM
