non cc q-jet
non cc q-jet
i'm gonna take the q-jet and distributor off a 78-79 z 28 for my 84 lg4 the z28 has a stock 350 in it, and i would think that it has the original carb. will this run OK for me, will it pass emissions?? Should i put the metering rods from my original carb in it?? i'm also putting in a stealth intake. Will my stock intake fit under the hood? what kind of 14x3 would fit?? i wouldn't mind an edelbrock elite triangular with generic k&n. they have a dropped base and clear HEI dists.
'84 Berlinetta, LG4, 700R-4, starwars interior, falling headliner, T/A t-handle shifter, trans cooler, more to come in time and $$ www.hipergp@aol.com
Transmission: 4L80E/4L80E
Emissions visual inspection? No. Emissions sniffer? Maybe, if you keep it lean enough.
Which metering rods are you talking about? The primaries won't work, the secondaries from your CC carb probably aren't optimal.
I wasn't under the impression that a q-jet would mount on a Stealth; if that's true, you'll need an adapter, which will raise the air cleaner, reducing hood clearance, reducing flow, etc., etc., etc. But, my dropped base 14x3 clears the HEI, for what that's worth.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
that's right, i never thought about that- qjets can't bolt directly to a stealth. crap. it'll never fit under my hood with a spacer. maybe i'll just bolt it to the stock manifold until i get a new hood.
