how could i make my secondaries fully open faster?
Old Oct 21, 2001 | 03:39 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i was wondering if i could do this becuz i was lookin at it and it takes a couple seconds for it to open fully when i raump on it
wouldnt this help me if i made it open faster....or would it be too much gas and air at one time??
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Oct 21, 2001 | 10:30 PM
82camaro's Avatar
Car: 82 camaro SC
Opening too fast can slow you down. Yes you can adjust it. Opening it adds air, put if you don't have enough velocity you won't get enough fuel to go with it.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Grant2k
Jul 10, 2018 04:01 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
