Q-Jet ID
Old Nov 16, 2001 | 02:08 PM
E-Z Rollin's Avatar
Q-Jet ID
I have a Q-jet # 17054919 2576. Anyone know what the original application was?
Old Nov 16, 2001 | 02:33 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
That is an odd one... it lists as a '74 carb made after '75 and it doesn't even classify as any type of carb they made (Q-jet, monojet , etc.) You may have written the number down wrong... go check it and see if you wrote it correctly.
Old Nov 16, 2001 | 05:31 PM
E-Z Rollin's Avatar
Yes it is odd,but that is the right number.It has the gas line fitting at a right angle like a chevy and is in great shape.I'm going to use it on my V8 S-truck project but was curious because I can't find it's original application,maybe a Q-Jet rebuild kit catalog ?
Old Nov 17, 2001 | 11:51 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Well, I found some carbs with similar numbers (6,7 and 8 instead of the second 9). Since the last number mostly says if it was auto or stick... The info I found was that it was either off of a 402, 427 or 454... they were all truck engines from '68 - '71
Go <a href="http://www.quadrajet.com/Kits/chevy.html">here</a> for all the info.
Boy I wish there were a site that had every carb number ever used...
[This message has been edited by ChillPhatCat (edited November 17, 2001).]
Old Nov 18, 2001 | 11:09 AM
E-Z Rollin's Avatar
I found a site called carbs unlimlited,punched in the number and got:73 GMC/Chevy truck 350 rebuilt carb.
69GTOby
Apr 18, 2016 02:34 PM
Zio
Carburetors
Apr 13, 2001 11:18 AM
fulo
Carburetors
Jan 28, 2001 02:04 PM
Z28HO
Carburetors
20
Jan 2, 2001 03:39 PM
Z28HO
Carburetors
Oct 5, 2000 02:58 PM
