how to on float level
Old Nov 30, 2001 | 08:58 AM
86-red_dawg's Avatar
so i rebuilt my carb, following the haynes manual, and they don't really give a good representation of how to properly set it - from what i can tell, i push on the end so that the float is at it's highest level, then measure the distance from the float to the top of the metal rim, right? well i did so and it reads about 8 or 9/32 and it says it should be 11 - so am i supposed to take the float out and bend it or something?
Old Nov 30, 2001 | 01:14 PM
Damon's Avatar
Yep, you bend the float arm. There is a built-in weak spot in the arm on the float side of the fulcrum where you bend it.
pjsparts
Oct 29, 2025 06:39 PM
86z89iroc
Oct 5, 2015 01:04 PM
mfp189
Sep 27, 2015 09:25 AM
Springster
Sep 13, 2015 01:38 PM
Formula_88AE
Sep 3, 2015 01:47 PM
