holley fuel pump....no return fittin?
Old Dec 1, 2001 | 11:32 AM
1982chevycamaroz28's Avatar
well i dunno where to post this so....my brother got a holley fuel pump awhile back from jegs and well they sent him the wrong one like they gave him a better one then the one he was suposed to get and well he had sum problems with it not like givin it enuff fuel like it would almost die sumtimes and well i was wondering is there any way to kinda make ur own way to egt it to no do that like it has no return fittin on the pump and i was wounderin if u use a t fittin and sum tubeing and what not will that help and also i might be goin to use that pump since he took itoff so he could use te stock pump, becuz i got nos and well i need a better fuel pump so i figured id use that one. so if anyone has any suggestions that would be great thanx.
Old Dec 1, 2001 | 02:06 PM
Jester's Avatar
Ugh...my eyes hurt. I suggest going back to elementry school to relearn basic spelling and grammar.
Old Dec 1, 2001 | 02:37 PM
hey buddy i dont need ur comments just any solutions to my problem thanx. anybody else have any solution to the holley pump problem
Old Dec 1, 2001 | 04:59 PM
Guest
Guest
Posts: n/a
That was all one sentence? Impressive.
Old Dec 1, 2001 | 06:03 PM
yea who needs periods here and there :-). just kindin i just need to get it down with out worring about grammer becuz i had to go at the time and only had a min to get that all down.
Old Dec 1, 2001 | 06:23 PM
Helmsdini's Avatar
I read that post 3 times and still havent the slightest twinge of what in the world your question was. Take Jesters suggestion and try again when you have time.
Old Dec 1, 2001 | 09:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Comeon guys it isnt that ard just red btwen the messn ltrs an periods an stuf yu cant jst put a tea in there cus al the gas will jst go bak to the tnk if their isnt sum restricton in da retrn lin the factry pump duz dat wid a litl valv dat crks opn wen the press gits to high keping the rite press to da carb at all tims so if he wnts he can put a reg wid a turn lne wid da holey pmp or he cn putt a stok pmp on hids car an gve u da holey 4 yur nos sys dis is proly da rite plac to post dis ? gud luk
Old Dec 2, 2001 | 07:28 AM
ede's Avatar
ede
ah jest weesh u'd learn ta type and spell like i taulk then ther would be less chance of me messin up and not understandin what yourn tryin to say
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Dec 2, 2001 | 07:37 PM
Dr. Pepper's Avatar
Good golly guys. That is an interesting post, but to offer you good help I (we) need details. Exactly which pump did you end up with? Where was the fuel pump mounted on the car? Does the fuel pump run hot, does it sound like its running as a fast whirl or a slow grinding noise? I have had many problems with the Holley pumps, including having the magnets come off in the motor. When that happens the pump spins very slowly or doesn't spin at all. Not many carb pumps have return lines. It would be a nice feature to help keep the fuel cool but everything should still work without a return line. You need to first check to see if the pump is working right and if its getting fuel to it. You can't pump fuel if there is no fuel there to pump. If the fuel pump is out of the car you can try testing it with a little water. Put a piece of hose on the in and out connectors. Put the in hose in a bucket of water. Hook a battery to the pump with a pair of jumper cables. In a second or two water should pour out of the out hose. When it does unhook the motor. You don't want to pump a ton of water with it, just enough to see if it works.
Old Dec 2, 2001 | 08:23 PM
five7kid's Avatar
Mechanical pumps don't tend to make whiring noises, or do much of anything when you hook them up to a battery...
Old Dec 2, 2001 | 08:30 PM
well its a mechanical pump not an eletric pump. so i cant really test it out. but like when my brother had it hooked up when the car was runnin it would make a loud clickin noise, i dunno if thats good or not. but like when he had the stock pump on the clear fuel filter would be full but with the holley it would be like half full with alittle bit of bubbles. i think the part number for it is like 12-834 or sumthing like that. but could i rig a way to still use the return line to it or no. and would that give me enuff fuel pressure to run my Nos right and not screw things up.
Old Dec 3, 2001 | 11:08 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
i too have the 12-834 holley fuel pump as the suggested in the chp magazine for my 87 z. it doesnt have a return fitting, you guys say that its only necessary for cooling down gasoline? as it is my car isnt smog legal anymore for the time being and id like to try this new pump out.
1987 LG4 Camaro z28
Mods- 80 series flowmaster, k&n filtercharger, open air element, cat pipe delete, 180* stat, edelbrock performer intake, msd blaster coil, ascd big block hood, panasonic cd player, rockford everything else.
[This message has been edited by z28onTweenkies (edited December 03, 2001).]
Old Dec 3, 2001 | 02:58 PM
82camaro's Avatar
Car: 82 camaro SC
You can't just t-in a return line to the output line. You will have little or no pressure, because the return line runs straight to the tank without restriction. If you want to use the return line with that pump, get a pressure regulator with a return line provision. Excess pressure will go to the return line. The return line is to reduce pressure(and can help with vapor lock). That being said, a carb needs enough volume to sustain the maximum fuel flow your engine needs. The only part a carb that has pressure is the needle and seat.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 3, 2001 | 03:05 PM
where can i pick up one of those pressure regulator thingers with the return line provision. if i dont put that on will there be anything wrong with usin it yes or no and what will be wrong? thanx
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
