Carb Cleaner
Old Dec 5, 2001 | 07:25 AM
MD83Z's Avatar
Carb Cleaner
Last winter I soaked my original CC carb. in gasoline for about a week. Now that it's replacement (junkyard) works so well with Damons adjustments and rod-hanger ideas I want to rebuild the original. Has the gas ruined the solinoid or anything else? I forgot about the electric controls when I dipped it.
Old Dec 5, 2001 | 11:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You just put the whole carb in a bucket of gasoline for a week? I'll have to admit I've never heard of that one.
You probably didn't do the TPS or choke pull-off any favors. I'd replace them at least. The MCS may also be less than a happy camper. Everything else should be included in a rebuild kit.
It probably didn't help anything, either, because you're using for a solvent the very substance that left the deposits you're trying to remove.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Dec 5, 2001 | 12:37 PM
MD83Z's Avatar
2 1/2" in a tin to lift the grime away,then scrub with a toothbrush and paint. at least it looks new on the outside. The post about the tranny fluid in the master cyl. got me thinking about melting plastic or something.
I'll try the rebuild and pull parts from the working one if needed.Thanks,I have suffered with this 305 for 18 years, and now that this board has it reving up I'm worried it could fly apart.
[This message has been edited by MD83Z (edited December 05, 2001).]
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
PurelyPMD
May 5, 2016 04:57 PM
bbsr72
Apr 2, 2016 09:12 AM
codeysabatini
Nov 10, 2015 04:07 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
