Computer and carb
Old Dec 10, 2001 | 09:19 AM
VampireHunterC's Avatar
Computer and carb
This is probably gonna sound stupid, but what exactly does the computer do with the carb? If it only regulates the air/fuel mixture and idle, can you unplug the carb from the computer and adjust the idle and air/fuel mixture manually?
Old Dec 10, 2001 | 10:42 AM
Damon's Avatar
In a word, no. The ECM does regulate the A/F mix from idle through about 1/2 throttle. If you disconnect it, it goes full-rich. The components inside the carb however, do not lend themselves to maunal tinkering. They are designed to be cycled quickly between open and closed by the ECM. You can't just set them "in the middle somewhere" and get an in-between air/fuel mix.
Old Dec 11, 2001 | 05:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
And, the ECM does not directly control the idle speed. That is all mechanical adjustment.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
