street avenger kick down cable
Iam one day away from being done with cam and cfi to carb swap. I can not figure out how to mount the kickdown cable. I have performer RPM intake and SA 670 carb can anyone help. The trans is turbo 350.
Transmission: 4L80E/4L80E
What do you mean by "mount"? Attaching the cable to the carb, or attaching the cable housing to the intake manifold?
If the former, check out Holley 20-37 stud kit (HLY-20-37 on www.summitracing.com). Or whatever style your cable is. If you do a p/n search on HLY-0-80670, and click on "other suggested parts", a list of studs and brackets will come up.
The 20-95 has both the throttle and tranny cable mounts. It says it's for TH700 trannies, not sure it is different from your kick-down cable, though.
wigmobile
Feb 26, 2025 02:56 PM
86CamaroDan
Sep 29, 2015 10:08 PM
