Will I Need To Adjust the A/F Screws
Old Jul 28, 2002 | 05:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm going to be swapping the cam and intake out of the car soon. I'll be going from a 390/410 lift cam and stock LG4 intake to a Comp 268XE 477/480 lift cam and the Weiand Stealth intake.
Will I need to readjust the AF screws on my 600 Edelbrock carb? If so what's the proper procedure, I thought I read somewhere once to hook a vacuum gauge up to the carb and do it that way somehow.
Thanks.
Old Jul 28, 2002 | 10:36 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes your going to need to readjust the AF mixture to get the best results and possibly re-jet or at least swap springs. If you use a vacuum guage your supposed to turn the A/F mixtures "edelbrock" clockwise until you reach peak vacuum then turn it up to 1& 1/2 turn more. Since you have an edelbrock just max the screws clockwise and then back them out 1, 1/2 a turn each. This usually gets a edelbrock very close, at least it will give you a base setting to tune from.
Mark_ZZ3
May 24, 2018 01:02 PM
86IROC112
Oct 9, 2015 10:38 PM
Damon
Sep 26, 2015 04:29 PM
greenyone
Sep 8, 2015 08:41 PM
