is this 750 makin me stall??
Old Sep 2, 2002 | 11:19 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys with the set up in my sig. i have a 750 edelbrock and when i get on it and then hit the brakes or turn hard it will stall the car.could this be that i have to much carb for this engine and i am floodin it? it does bog a little bit. do u think my combo woudl run better with a 650 maybe. also my powersteering pump leaks a little and i was thinkin maybe thats it cause it happens when i turn alot? thankls guys
Old Sep 3, 2002 | 01:32 AM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
my friend had that problem in his 76 maro. turns out his engine wasnt creating enough vacuum because of his large cam to keep the engine running when he hit the brakes hard. just a thought.....
Old Sep 3, 2002 | 10:42 AM
Car: 89 Formula
Engine: Carbed 5.7
how did he fix this??
Old Sep 3, 2002 | 12:01 PM
curt86iroc's Avatar
Car: 1990 IROC
hehe, he didnt. it still happens if he brakes too hard. you can get a vacuum reserve canister from summit or jegs....
Old Sep 7, 2002 | 07:00 PM
Rancid87's Avatar
the cam in that motor probably isn't very radical. if it happens when you get on the brakes hard then you probably need to adjust the floats on the carb. readjust the floats and get the thing semi-tuned and you should be alright.
Old Sep 7, 2002 | 11:17 PM
Car: 89 Formula
Engine: Carbed 5.7
how do u adjust the floats on an edelbrock? all i know is there are 2 idel mixture screws and thats it.
Old Sep 8, 2002 | 08:33 PM
Rancid87's Avatar
to adjust the floats on one of those you need to take off the air horn cover. check the edelbrock website for some indepth directions.
Old Sep 9, 2002 | 06:30 AM
83 MidniteZ's Avatar
I thought with a loss of vacuum the power brakes would work sparatically. A vacuum cannister assists accessories, but doesn't affect the amount of vacuum produced by your engine.
curt86iroc, I would tell your friend to also check his float adjustment. I don't think something like that should happen at all and not have some way to be fixed
RedLeader289
May 28, 2019 01:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Briandrex
Oct 5, 2015 06:20 AM
Jlanz55
Sep 29, 2015 08:55 AM
