Slight problem with 84 Olds 3.8 mixture control
Old Sep 9, 2002 | 09:52 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I recently swapped my 2bbl intake for a 4bbl intake, and in the process changing from the original dualjet to an E4ME Qjet.
The motor doesn't really want to idle down, I'm sure I have a vacuum leak, but other than that it runs good at part and full throttle.
While watching the scanner, however, I noticed the the MC solenoid duty cycle is doing some WACKY stuff.
It'll sit at 5% at idle (probably cuase of the vac leak) for a little while, then it will suddenly jump up to 54% and sit there for a few seconds, and then jump right back down to 5%. You can hear the motor change idle speed and sound when it does this, so I have to think that it really is happening. The motor also wants to stall when it's at 54%.
Why the HELL is it doing this? the O2 sensor is still reading somewhat lean when it's sitting at 5%, so there should be no reason in the world why it should suddenly decide to pull fuel. When my Camaro was in a similar situation, it sat at 5% and eventually tossed a lean exhaust code, exactly how it should behave.
Also, the ECM does not throw a code when I disconnect the MC solenoid connector . It will throw one for EGR malfunction though .
I'm leaning towards it being something wrong with the ECM. I've never seen one of these cars randomly change the MC dwell like that without falling out of closed loop.
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
