84 Monte Carlo
Old Sep 9, 2002 | 08:51 AM
86TATpi's Avatar
84 Monte Carlo
A friend of mine has an 84 Monte w/ 305 carb engine (4 barrel). Problem is it runs like s$&* It's been backfiring through carb and or exhaust. It bogs when you hit the gas and has been doing that before the backfiring. The carb was rebuilt a while ago which seemed to help a little and the timing was advanced which seemed to help too. Now it's running like this. Any suggestions about what may be the problem? Also when setting the timing there is a four wire harness behind the distributor. Does this make a difference with how it is running now. All suggestions would be appreciated.
Old Sep 9, 2002 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 4-wire harness should have been disconnected when the timing was set, then reconnected. Was it?
If not, there's your problem.
Old Sep 9, 2002 | 08:47 PM
86TATpi's Avatar
He didn't disconnect the harness when setting the timing. But what I don't get is how it ran bad before he messed with the timing at all. Could the carb be shot?
jhawkeye
May 25, 2022 06:33 PM
Night rider327
Sep 16, 2015 02:20 AM
dans82bird
Oct 23, 2001 04:26 PM
CamaroX84
Aug 27, 2001 06:56 PM
vortech305
Apr 6, 2001 12:46 PM
