Why doesn't the air valve on my qjet open all the way?
Car: 1991 RS
Engine: 305 TBI
Why did Rochester build it this way? What could the advantage possibly have been? Was it to prevent bog?
Isn't the whole point of the air valve to open gradually to prevent bog anyway?
Who knows for sure. But, I know that a low compression 150HP 4500 RPM 305 doesn't need a full 750 CFM and all that fuel. Were you asking how to fix it? All you need to do is grind down the stop.
Car: 1991 RS
Engine: 305 TBI
Oh, no, I've read about how to fix it. I just wondered why they would do this. The design predates CAFE and emisions and all that other nonsense, so there should have been a real reason.
I mean, if you were to stuff a sock in your mouth before running a marathon, there must be a damn good reason for it, right?
By the way, how far do I grind down the stop? Do I want the air valve to be perpendicular to the bore? This wouldn't cause a bog, would it? Since the air valve is sucked open by the motor, it will only be opened the optimum amount, right?
Thanks,
Homer
P.S. I drive a 150hp, low compression 350. But I'm sure I don't need this yet either.
Thanks,
Homer
Grind it down till its between 85 and 90 degress. Make sure not to go any farther than that because 1 your not going to be gettting any extra flow and 2 I think if it goes more than 90 deg it can bind itself.
Car: 1991 RS
Engine: 305 TBI
Ok, I'll do that, seems simple enough.
I was looking at the carb earlier, and it seems almost like it was designed to be opened all the way. Even the secondary cam seems designed to give extra enrichment for a wider open air valve.
Did Rochester get paid off by Holley to shoot themselves in the foot powerwise?
And a well tuned QJet can make just as much power as a Holley of equal CFM. Rochester designed the QJet for economy before performance - but you can change that. The Holley is performance only (sometimes
), and NEVER economy. Trending Topics
Car: 1991 RS
Engine: 305 TBI
Why is the Qjet so unpopular for performance? Lack of parts? It's too darn complicated? Distribution problems between front and rear cylinders?
Transmission: 4L80E/4L80E
The jets operate straight in a Holley. Extra enrichment is provided via a power valve, which operates separately from the jets (but flows through the same boosters).
I got spanked a couple of weeks ago by a '67 Nova stock class 327 q-jet that ran 12.2's here, 11.7's at Topeka (.9 under the index). Don't try to tell me q-jets can't run and can't be made to run consistent.
Car: 1991 RS
Engine: 305 TBI
I'm very glad to hear from many different sources that the Qjet can run well. I have a Qjet and I'd rather run that than swap something else in.
I have another question, however. I noticed the other day that the secondary throttle blades don't open all the way. Is this normal? Should I attempt to correct this?
https://www.thirdgen.org/techbb2/sho...hreadid=132375
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
