350 feels like 305
Car: 1978 Chevrolet C10
Transmission: Turbo 350
350 feels like 305
ok well i finally got my 350 running. well i took it for a drive and when i hammered it it felt like it didnt pull as hard as my 305 did, i thinkt aht the secondaries arent opening at all.
so how can i fix this, also can you post pictures about this so i can see the process or what to look for... thanks for the help.
so how can i fix this, also can you post pictures about this so i can see the process or what to look for... thanks for the help. Member
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
it looks like there's a thread a few below this one that applies to your problem...looks like he had the same thing.
https://www.thirdgen.org/techbb2/sho...hreadid=134785
hope that helps.
hope that helps.
im forced to be running the stock system... lack of money suckes because i have a system jsut dont have the money to have it put on.
when I did my carb and cam swap you couldnt tell a differance becasue I had the cfi exhaust manifolds, and crappy exhaust. once I put the headers and cat back on the car opened up and I can tune without detonation. Have checked compression, and timing?
everything is great, car runs beatiful now that i got the secondaries to open. they werent opening at all. not its fast as ****... thanks
