timming stay the same with vacume advance off?
Old Oct 3, 2002 | 10:07 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys when i go to time my car i will shoot the light on and see the timming then pull off the vacum advance line goin to the carb cause i thought u where supposed to adjst it with it off. well when i pull it off it doesn;t change the timming. is there somthing wrong here?
Old Oct 4, 2002 | 07:52 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
You are supposed to disconnect the vacuum line at idle like you are doing.Make sure you are plugging the port on the carb after that step.The timing should not change when you unhook the vacuum line,there should be no vacuum pulling on the advancecan at idle hence the lack of change in your timing when you undo the line.
gta892000
Aug 11, 2019 11:16 AM
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 20, 2015 06:59 PM
timonator
Sep 17, 2015 06:57 PM
SG91camaro
Sep 5, 2015 10:27 PM
