750 double pumper pouring gas in intake
Old Oct 9, 2002 | 09:17 PM
jamesbern's Avatar
I don't think it has anything to do with fuel pressure because my Edelbrock 750 works fine. Just kitted this double pumper to fix some leaks, but I had used it before and it ran pretty rich, but it ran. It literally pours gas in, caught my headers and intake on fire. It will run for about 30 seconds after removing the carb with all the gas its dumping. When I had it apart I noticed that both metering blocks had a power valve in them instead of the typical plug in the rear. It has to be coming through the bottom or middle of the carb because I can't see it dripping or running out of the squirters. Just looking for similar experiences or advice because I have never seen this before. Thanks!
Old Oct 9, 2002 | 09:28 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I would check the power valve. I had this problem at one time, and tore the carb apart, change the primary valve, and cleaned the needle and seat. One of those 2 did it, cause it ran great after that.
Old Oct 9, 2002 | 10:41 PM
jamesbern's Avatar
Yea, I checked the power valve, but that wasn't it.
Old Oct 10, 2002 | 12:52 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Wrong metering block gaskets or power valve gasket.(s)
Wrong main body to throttle plate gaskets.
Old Oct 10, 2002 | 05:49 PM
jamesbern's Avatar
I'll check that then, thanks!
db057
Sep 4, 2015 07:57 AM
mustangman65_79
Sep 1, 2015 03:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
