how does CC carb work?
Old Nov 25, 2002 | 08:23 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
what do the wires on a computer controlled carb do. its a Q jet from a 86 bird 305.
Old Nov 25, 2002 | 08:30 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
Well the three wire connector on the drivers side of the carb is for the Throttle Position Sensor. The other connector on the car is for the mixture control solenoid.
Old Nov 25, 2002 | 08:39 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
the mixture is comp controled? the reason i ask is ive been running the car without anything plugged in to the carb(on purpose) for a couple years.
Old Nov 25, 2002 | 08:49 PM
meridius's Avatar
Yes it does control the mixture to a point. If you had the tps disconnected how was the timing doing? I see by your sig you have a 700 behind your engine so that brings up another wuestion, how was the tcc activated? Im just curios becauseif everything else is stock it wouldnt be running very good due to the timing curves.
Old Nov 25, 2002 | 09:08 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
i have no computer. i shift manualy. i got a HEI from the junk yard
Old Nov 25, 2002 | 09:11 PM
meridius's Avatar
I see well that takes care of the timing but what about the locking up of the converter I take it yours dont lock up at all then.
Old Nov 25, 2002 | 09:16 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
no but it pretty much only gets driven to the track and im going to get a t350 when i finish the 355 in the spring so i dont care.
Old Nov 26, 2002 | 09:48 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
With a non-computer distributor and a computer carb, you're going to run filthy stinking rich on the primaries. That's it.
Old Nov 27, 2002 | 08:40 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
i got this engine from a buddy that had it in his 86 bird and without the computer and stuff my car runs faster than his did at the track. it cant be running that rich.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
stalkier
Aug 13, 2015 12:59 PM
