Fuel Pump selection for Q-jet?
Old Dec 30, 2002 | 11:20 AM
PeteZ28's Avatar
Car: 84Z28, 98Z28
Engine: roller 350, cc Qjet
Transmission: WCT5
I'm just wondering what a good mechanical fuel pump is to use on a ~350hp 350 with ccc Q-jet. I am hoping to retain the return line since it's there to reduce fuel temp and prevent vapor lock.
Any ideas? Is the return line really necessary? What are some of the rest of you running?
Pete
84Z28, almost 350, WCT5, 3.42 posi-disks
Old Dec 30, 2002 | 02:15 PM
Momar's Avatar
Well, I am going to try running the stock replacement pump from the l59 which seems to be the same as the lg4 pump. If it doesnt give enough fuel I have seen where it was suggested by Damon I believe to run a low pressure carter inline electric pump before it. If the return line is still there you can feed it more fuel without a problem I would think. From everything I have read quadrajets dont like fuel pressure though, just volume.
Ben
Old Dec 30, 2002 | 05:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The stock L69 pump is enough to power my 400 with big heads, 282 roller cam, 800 CFM Holley, blah blah blah.... I have no doubt it will do just fine on a little motor like a 350.
Old Dec 30, 2002 | 06:41 PM
PeteZ28's Avatar
Car: 84Z28, 98Z28
Transmission: WCT5
Thanks for your help guys. I didn't realize the stock L69 pump flowed that much fuel. Actually Ben L69's already a booster pump in the tank. But thats a good point, flow could be increased behind it with an aftermarket electric pump. I guess I'll start with a stock set-up. Any particular supplier for a new L69 mechanical pump?
Thank
Pete
Old Dec 30, 2002 | 06:47 PM
Momar's Avatar
Yes, I did realize that the l69's had a pump in the tank, but didnt know if you had a l69 or lg4. I had the lg4 so I dont have an in tank pump. I figure if I need more fuel than just the mechanical pump alone will provide, I will use an aftermarket inline pump.
Ben
Old Dec 31, 2002 | 06:58 AM
Changa2's Avatar
Ben, I believe you will find that an LG4 does have an in-tank fuel pump. It functions as a booster to compliment the mechanical pump.
My (87) LG4 has both.
Old Dec 31, 2002 | 07:20 AM
Momar's Avatar
I believe that 87 was the only year that the lg4 had the in tank pump but I could be wrong. That is what I have read in the past though.
Ben
Old Dec 31, 2002 | 01:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My '86 LG4 donor car did not have the in-tank electric pump.
I'm running an AC replacement pump with no fuel delivery problems in 3 years. The original which was on the engine when I got the donor car was a different story, although it didn't look all that old.
Old Dec 31, 2002 | 03:16 PM
84TAProject's Avatar
My 84' LG4 does not have an in tank pump. My stock fuel pump was spraying oil under the hood, and I replaced it with a high volume chrome mallory one as I plan on a blower in the next few years and figured why not. I dont have the return line with it, it runs fine, although my cheap gauge says it runs 9-10 lbs of pressure which is high i think, but Im not sure if I should drop fuel pressure with a regulator or what.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
