Kickdown
Old Feb 6, 2003 | 07:03 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
Kickdown
ok i got a 1850 4160 series 600cfm holley and a 200c transmission.....now there is no sort of kickdown hooked to the carb.....where does it go and what kind of bracket do i need
Old Feb 9, 2003 | 01:14 PM
Car: 83 Camaro
Transmission: th350
ttt
Old Feb 9, 2003 | 02:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check out the on-line catalog on Summit's website. Look under air-fuel delivery/carbs. Holley has some throttle linkage studs, and Summit has the cable housing bracket.
Old Feb 9, 2003 | 07:07 PM
Car: 83 Camaro
Transmission: th350
that sounds like throttle stuff...does the kickdown cable hook onto the throttle bracket using one of those stud things or something replacing the one where the throttle line hooks up to the carb?
Old Feb 9, 2003 | 08:35 PM
ronterry's Avatar
Car: '94 Corvette
I think all you need is a kick down stud (Holley#20-40). Not sure where it's mounted on the lever? Might need to drill?
You might need a bracket to hold the cable in place (Holley#20-45). This is for the TH-350, but I believe they use similar sizes.
I company called Lokar also makes varies brackets...You can find there parts on Summit.
Sorry, but I know of know of no such combo with Th200c & Holleys. Normaly there is QJets with Th200C stock...
Ron
Old Feb 9, 2003 | 09:09 PM
Car: 83 Camaro
Transmission: th350
lol...who ever said i was stock.....ok thanks though guys.....i was lookin and it looks like that stud goes on the bracket i have for the throttle but like a inch below
Old Feb 9, 2003 | 09:19 PM
Car: 83 Camaro
Transmission: th350
Old Feb 9, 2003 | 09:36 PM
ronterry's Avatar
Car: '94 Corvette
Oh - I knew it wasn't stock , but popular combos usually have a parts following…
Ron
Steve86TA
Jan 3, 2003 02:18 PM
PPonU4Me
Jun 4, 2002 07:10 AM
dennis6
Carburetors
Apr 1, 2002 02:56 PM
yOp 84 Recaro
Mar 14, 2002 04:39 PM
