Edelbrock TH350 Kickdown question
Old Mar 24, 2002 | 11:36 PM
dennis6's Avatar
Car: 1991 Camaro RS
I need a cheap linkage to go between the kickdown cable on TH-350 automatic tranny and an Edelbrock Performer 600 carb. I have the cable and the cable mounting bracket, just nothing to hook the cable to the carb. Any info would be apreciated.
Old Mar 26, 2002 | 08:22 AM
Damon's Avatar
I got a "maybe" solution for you. I had a problem like this a few weeks ago with a Holley 800 that had the original kickdown stud and arm hacksawed off but I needed to use it in a TH350 application.
Edelbrock makes a little "arm" that bolts on the original thottle arm. Costs $6. The kickdown stud you will also have to buy costs another $5. Why this Edelbrock part fit my Holley throttle arm is a total mystery to me, but it fit like a glove. I suspect that the Edlbrock and Holley throttle arms are sufficiently similar where it bolts on to fit either carb.
Good luck. Sorry, no part numbers, just threw out the packaging. It's just a flat piece of metal with one large hole and a few small ones drilled into it.
Old Mar 26, 2002 | 05:49 PM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks! I bought the stud right after I posted, but I couldn't find the adapter under 40 dollars. I got some searching to do.
Old Mar 26, 2002 | 05:57 PM
dennis6's Avatar
Car: 1991 Camaro RS
Would this be the "arm"?
EDL-1997 Quadrajet Throttle Kicker Bracket $6.95
Old Apr 1, 2002 | 02:56 PM
Damon's Avatar
The arm I'm referring to would definitely not work on a QJet. It would only work on a Holley or maybe an Edlebrock Performer carb.
beastin91rs
Oct 9, 2015 07:38 AM
fasteddi
Sep 2, 2015 10:29 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
