rods and hanger
Old Mar 13, 2003 | 08:35 PM
white 81's Avatar
rods and hanger
I have a rebuilt 350, mostely stock with headers and dual exhuast, no cats. The rods in my CCC Qjet are DG on a N hanger. I have a flat spot when I floor it and in examing my plugs I think im running a bit lean. (they are white) What hanger and rod combinations do you recommend for my setup?
Old Mar 13, 2003 | 09:07 PM
Gruvin84SS's Avatar
DG 1342 1244 1075 847 547 337 337 M 7048890
DG rods are rich for your application. A DR with a B hanger is a good set for a 350. If you find that your are actually lean after a WOT run(WOT plug cut) then I would check your secondary air valve setting and your WOT fuel pressure.
HTH
Old Mar 13, 2003 | 10:49 PM
white 81's Avatar
what about a CK rod with a B hanger? I dont know exactly how close to stock the 350 is or what kind of cam is in it because I bought it that way. The headers are long tubes and I also have a MSD 6al.
Old Mar 14, 2003 | 01:28 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
" I also have a MSD"
then don't put too much stock in the plug color.
Tune for best MPH over a said distance of acceleration.
Believe the ET/ MPH slip before the plug color.
As long as there is not signs of danger/ leanout
( detonation, over heating tip etc) and you get more MPH (go faster), it is not too lean.
The plugs will get colored by idle and cruiseing much more than
WOT testing. epecially with a MSD and unleaded gas.
Old Mar 14, 2003 | 09:47 AM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
im running CK's and a B hanger on my 305. helped me out a lot. the old rods were crap. i would use DR rods though on a 350 just because it needs a little more fuel than my car.....
Old Mar 14, 2003 | 07:57 PM
white 81's Avatar
thanks for that info F-BIRD88. Anyone know where I can find some DR rods?
Old Mar 15, 2003 | 07:01 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
www.carbs.net carbs unlimited
Old Mar 15, 2003 | 07:25 PM
white 81's Avatar
I didnt see a DR rod at carbs unlimited... anyone know of another place?
Old Mar 17, 2003 | 10:06 AM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
I got mine from Jet Performance through tec assistance.
Old Mar 17, 2003 | 12:42 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I ordered mine from Edelbrock through Canadian Tire.
Check www.edelbrock.com
CK rods and B hanger. Made a world of a difference.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
