Alternative to Proform
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Well, I didn't have the $100 to shell out for a Proform main body, and eBay didn't have any going any cheaper at the time, so I did some work myself. I didn't really hit the venturi's real good, b/c I don't trust myself not to accadentally change the shape. Anyway, here is a pic.
Car: 1991 Z-28
Yeah, I thought of that. But after reading the article in Car Craft I think on tuning with air bleeds. They didn't gain much in terms of drivability compared to a non-air bleed tunable Holley. But, that is one thing I do not have.
Car: 1991 Z-28
Sure. It originally looked like the pic below. I took a cut off wheel and trimmed the choke horn off. Then made a series of vertical cuts next to the air cleaner stud hole. I took some plyers and broke off the little pieces very carefully. I then took a die grinder with a carbide bur, and smoothed out the rest. After that was done, I used some sanding rolls from my SA Porting kit, and did the rest. To finish it up, I used the cross buffs in the kit to smooth it out real nice.
Car: '94 Corvette
AAA-Ada-boy johnsjj2 !!!
I'll take my hat off to you, cause I know the work involved.
I did that with an AFB though. What a PITA !!!!!
I was thinking about doing my Holley this summer.
Still up in the air. However I was going to try something a little different. I was going to use my drill press, & some milling bits.
I'm still looking for the bits, though
Looks realy good, ohhh and screw the air bleeds. Every book I have says stay away from adjusting or drilling airbleeds, and jet it with (drum roll please) the jets!
Ron
Ron
Car: 1991 Z-28
Thanks Ron. I would be willing to bet doing that with a drill press would be so much easier. You could control how much you took off much better. If you notice I went through in 2 spots. Had to use the 'ol JB Weld to fix it. The one hole was for the choke rod, the other 2 are on the opposite side. One on top, the other just below going through the side. All is good now though.
Car: '94 Corvette
JB Weld is fine with a carb, in fact thats the best aplication for it.
I used it to mount/glue a vacuum port, that I had to drill into the base. My carb (Holley #9381) is a race only and has no provisions for any vacuum hookups - like my brakes
. My intake for the record is a Victor Jr., and also has no tapped holes. It was easier to drill the carb.
Anyways, it looks great. You should of done a tech write up!!!
Ron
. My intake for the record is a Victor Jr., and also has no tapped holes. It was easier to drill the carb.Anyways, it looks great. You should of done a tech write up!!!
Ron
Car: 1991 Z-28
Aaaaaarrrggggg.........I didn't even think of that!!! When I make my SFC's, I will write one about that if it hasn't been done already.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Looks good.
Currently mine has no choke tower, but it isn't as smooth as yours...
Might have to do that.....
raymondandretti
Sep 27, 2015 06:43 PM
