Keeping stock fuel pump and using a pressure regulator for my carb?
Car: 88 Z28
Engine: 408 Small Block
Transmission: TH350
Axle/Gears: 9" w/ 3.90's
Im going to install a carburated 360cu in sbc in my 88 Iroc, but dont feel like making a new plate for the top of the fuel tank. I was wanting to know if it was possible to just add an inline regulator to reduce pressure at the carb.
Would that work?
If so what would be a good regulator for my situation?
Any other suggestions on how to convert to a mechanical pump up front?
Would that work?
You Need A 3 Port AFPR Return Style Regulator, I no Barry Grant and Mallory both make them. I did the same conversion and just bought a electriv pump out of a 76 chevy monza and modified a plate it was very easy and worth the money i saved.
Car: 88 Z28
Transmission: TH350
The pump conversion would be a cool one to see.
Also...Could I make a block off plate with a pickup line and use a mechanical pump up front?
Yah you cood just buy a mechanical pump and a pickup. Theres also four lines from the tank, a breather mounted beside the tank, a vent that goes to your charcoal canister and 2 main fuel lines, one line has a hose clamp and the other has a fitting. You only need to use the one with the fitting. My tank is still outa the car so i could get u some pics probly in the next week but i dont have any on hand.
Car: 88 Z28
Transmission: TH350
Please do that....
I wont be running the smog equipment so the charcoal canister will be gone too.
Let me know man.
Let me know man.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
im actually using 2 pumps..
my stock intank and a holley red..along with a 3 port holly AFPR..
this way niether pump has to work very hard..so theyll last longer
besides when i install my nitrous kit, i wont have to worry about fuel
To use it for any appreciable amount of time, you must run at least a 3 port, bypass style regulator. Numerous companies make them but the 3 port Mallory and BG are the only ones under $100.
And F-Crazy, it doesn't work like that. AN inferior pump inline with a better pump will make the better one, the red pump, work HARDER.
umm..I'd get something bigger. Especially if thats on juice...or at least get a second pump for the juice.
You can go here for more details on it's capabilties.
http://www.holley.com/HiOctn/ProdLin.../12-801-1.html
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I wouldn't trust a Red pump alone if you are planning to spray also.Go with the Black pro series pump..I have ran this pump for the last 4 years with a 150-200 shot and have yet to have a fuel starvation issue with my car.I also run the Mallory regulator with a return line on my carb setup.
Car: 88 Z28
Transmission: TH350
I bought this one but I dont think it will work now!
I found some Mallory .pdf files on it and they have a separate regulator for return style apllications and this isnt it!
Would it still work by sending the fual back down the return line from the 3rd port?
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
No it won't work..you need the Mallory #4309 IIRC.That is the bypass style regulator.By using the third port on a regular regulator as a return the fuel will just bypass the carb..path of easiest resistance..and go back to the tank.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Heres a picture of my 4309 mallory regulator. Worked fine with my stock TPI pump. I also bought (and payed way too much for) the Accel TPI to AN fittings to hook them up to the stock rubber hose.
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
