Code 45
Old Apr 30, 2003 | 01:38 PM
kev_n_ang_ta's Avatar
Car: 1984 TA, 2001 Monte Carlo SS
Engine: 305 LG4, 3.8 200 HP
Code 45
I have a 84 TA with a lg4 stock engine and I was on a back road going slow (go figure) and got a code 45 does anyone know why I might have got this. I did a search and didnt come up with any thing that had a carb so I thought I would be better off here.
Old Apr 30, 2003 | 01:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Means the ECM couldn't lean out the mixture as much as it thought it should be able to.
Check ignition and timing first. Most "carb" problems are caused by ignition, anyway.
After that is given a clean bill of health, if it continues to do that, do the carb adjustments (TPS, IAB, float, etc.). Q-jets are also known to leak from the two lead plugs on the bottom of the fuel bowl - that sit right in the intake tract.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
