what cam/intake for my carbed 305?
Old May 20, 2003 | 09:13 AM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
what cam/intake would allow me to get the most out of my stock motor...keep in mind though...everythings stock except for the carb (electric choke edelbrock 600cfm) heads and everything else are stock...dont know when i'll be gettin new heads, but ive heard of some nice power increase by switching to another cam/intake
Old May 20, 2003 | 09:20 AM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
anyone?
Old May 20, 2003 | 12:43 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The Edelbrock Performer RPM works great on the 305. Just block off the exhaust crossover passage with some epoxy or silicone and you're all set.
As for cams the LPE-216 is nice in a 305. The only thing there is that you need to change your 1986 engine to run a hydraulic roller camshaft. You'll need aftermarket hydraulic roller lifters and a different timing gear set with a cam button to control endplay of the camshaft. It costs more to go roller, but it will be worth it. The cam and all associated equipment will swap right over to most other chevy smallblocks later if you decide on a bigger engine.
here's a little more info on those parts.
http://www.cardomain.com/member_page...217306&page=18
Old May 20, 2003 | 11:05 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
where can i get a LPE-216 and how much does it cost?
Old May 20, 2003 | 11:24 PM
Jester's Avatar
Go cheap with the cam, so you're not out much when you get another motor. There are many cam/lifter packages for under $100 that will do you just fine, rather than spending $800 for a lingenfelter cam and all the retrofit-roller gear. Something like the 214/224 Summit brand cam is fine.
Old May 21, 2003 | 09:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Will the Edelbrock Performer fit under the hood of a thirdgen?
JamesC
Old May 21, 2003 | 11:40 AM
Marc 85Z28's Avatar
Yes, the regular Performer fits fine, even with large aircleaners. A Performer RPM will fit too, but only under a Camaro with a drop base aircleaner.
Old May 22, 2003 | 12:04 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Lingenfelter performance
http://www.lingenfelter.com/
$315 and expect to spend another $300 for lifters & timing gear.
You'll also want to get new valvesprings and modify your heads to take higher cam lifts, but It will be worth it to go with a great roller cam.
http://www.lingenfelter.com/lingenfe...24&pf%5Fid=489
Old May 22, 2003 | 08:25 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
GMPP ZZ4 intake manifold. Think summit is having a sale on CraneCams Powermax cams right now
pimp2303
Jul 27, 2017 02:03 PM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
