Holley Help
Old Jun 5, 2003 | 02:53 PM
-N-'s Avatar
-N-
Car: 1984 Berlinetta
Holley Help
Ok so my carb is dead and I want to get a new one. The old one had TPS and from everything I have heard I can run a regular carb. without any trouble. So here is my question what is a good Holley that gets better gas mileage that a stock but is still good performance wise?
Old Jun 5, 2003 | 03:13 PM
Guest
Guest
Posts: n/a
Re: Holley Help
2 OR 4 BBL?? i have a holley 600cfm carb and its ok on gas but its still a V-8 so its going to eat gas
Old Jun 5, 2003 | 10:24 PM
-N-'s Avatar
-N-
Mine is a 4 barrel
Old Jun 6, 2003 | 04:57 PM
-N-'s Avatar
-N-
Mine is a 84 Berlinetta would that still work with it?
Old Jun 6, 2003 | 06:47 PM
CamaroX84's Avatar
If you're going to switch to a non-computer controlled carb, you need to switch to a non-computer controlled distributor too. Then it will work.
Old Jun 6, 2003 | 07:16 PM
flyway190's Avatar
Here are a few threads that address this same topic:
Rochester Quadrajet Carb
83 H.O. stock carb??? or a Holley,etc...
q-jet to holley
Hit the search button in the top right corner to do a search for more info, there's plenty of it. I suggest you just rebuild the original carb, it'll probably come out to be cheaper.
Old Jun 6, 2003 | 08:58 PM
-N-'s Avatar
-N-
Ok thanks for all the help. As for rebuilding it I have been wanting to get some a bit better performance wise.
Old Jun 6, 2003 | 10:31 PM
MCas7's Avatar
Were you thinking about rebuilding it? I know someone that rebuilds them for pretty good money and they are very good at it. Let me know if you are interested.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
