Performer intake
Old Jun 9, 2003 | 09:45 PM
stupid4901's Avatar
Performer intake
I have the CC QJet is there anyway I can run an intake without the EGR setup? Can I use an Air Gap or does it have to be smaller then that?
Old Jun 10, 2003 | 05:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The computer sends commands to the EGR solenoid. If the computer doesn't sense the presence of the solenoid, it will turn on the "Service Engine Soon" light and set a trouble code. If you keep the solenoid plugged in electrically, it with be fat, dumb, and happy.
The ignition advance curve is calibrated assuming the EGR valve is doing what it is supposed to do. Without it, you may have pinging at part throttle loaded conditions.
Any intake that isn't made to mount a spread-bore carb like the q-jet will require an adapter. This raises the height of the air cleaner, but beyond that (and the general yuckiness of adapters), no particular problems.
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
DJanes97
Sep 1, 2015 02:55 PM
86IROC112
Aug 17, 2015 02:00 PM
