Square vs. Spread Bore...how to tell
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
How do I tell the difference between a Square bore and a Spread bore application based off looking at an intake manifold...or if anyone what the Holley 300-64 intake manifold is could you let me know......thanks.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Square bore carbs have four equal size throttle bores.Spreadbores have 2 small primaries and 2 larger secondaries..An example of a spread bore is a Q-jet..The intake for a sqare bore has a square flange while the one for a spread bore has the shape that outlines the sides of the throttle bores
Daz
Daz
Transmission: 4L80E/4L80E
I have the performer rpm spreadbore. I noticed that it has 2 sets of mounting holes(8 holes all together) for the carb. Was there more than one style mounting for spreadbores or what is the other set of holes for?
Yep.
http://www.edelbrock.com/automotive/index.html
Click on Intake Manifolds, Small Block Chevrolet, about 2/3 down is the description of your manifold that tells all.
gixxer92
Apr 12, 2022 12:09 AM
sreZ28
Oct 22, 2015 08:21 AM
roysatikas
Sep 22, 2015 08:15 PM
bore, carb, carburetor, difference, flange, intake, manifold, mounting, photos, spread, spreadbore, sqarebore, square, squarebore, vs
