Omg Some One Help!
Omg Some One Help!
i have a problem with my holley carb and i dont no what to do . first when it comes to start up> when i go to turn it on it wont start with out me putting some gas in the carb, and everytime i push the gas when the car is on it has a pause then goes (while reving and in drive) and if i hit it hard enough it stalls. what the heck it going on??? please any help would be great.
oh and i already replaced the accelerator pump diaphram.
Transmission: 4L80E/4L80E
With the engine off and air cleaner removed, look down the front two barrels of the carb (choke open as well - hold it open if you have to). Open the throttle while watching inside the carb - do you see a couple of squirts of gas?
i check that and no i dont see anything comeing out or hear anything shooting out, but i can rev it and once i do get it started (but not without the bog first) is there 2 diffrent lines or something??? what should i do?
Your accelerator pump isn't working for some reason or another. First make sure you've got it together right - the picture you posted on your leakage thread shows it correctly. Then make sure the innerds are in there right (Holley website has expanded views). Then, plugged passages or gaskets not installed correctly.
i was thinking i might have put it in wrong also but i really dont think i did i put plunger down then spring on top, also i gave it a lil test by not titening it all the why on and gave it some gas and gas did shoot out the sides.... so i bolted it in. i am gunna double check holley to make sure its plunger down. anymore ideas? i was thinking my fuel pump could be week.
oh and this other issue i am haveing when i hit the gas and it pauses then goes, do u think i am haveing this problem because of this fuel issue?
thanks alot for helping me man i have been posting in other sites and no one responds. keep the ideas comeing your my only hope LOL
oh and i tryed a comustion chamber flush today and no go, also i changed my plugs, still nothing
It was the symptoms you described that lead me to ask the questions.
You need to get that accelerator pump squirting into the venturis.
i have a problem like that too i have a holley 750 and i have been told that my carb is too big for the engine set up and when i race i cant get on it hard or else it stalls or it feels like it stalls then all of a sudden takes off like a bat outta hell which is cool in a way but it sux i have to slowly get on it when i race like give it half throttle and then eaz on the rest. my car runs rich as hell i had the carb turned down like all the way and it was still running rich. i dont know if that is your problem but i hope i helped.
no its not that, the carb has been sitting for a year so its all dryed out and prob need a rebuild my mechanic has it sitting in some stuff to see if that cleans it out. if not its rebuild time. but thanks for your thoughts and good luck dealing with your problem. if its 2 big y dont u just go get a 650
