misting carb with water to clean???
a friend of mine told me that you could get a spray bottle with water and mist over the carb while your running to clean it out is this true ??? or will i screw up the car even more??i have the same problem as the guy in the popping topic..new cap rotor wires checked timing plugs ..everything is ok but the carb is popping..when it pops smoke comes out of the carb.
any help would be great
thanks
any help would be greatthanks
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Injecting a moderate water spray into the carb while running at WOT will remove all the carbon build up in the motor's combustion chambers. The water turns to steam and we all know the cleaning power of steam.
Be aware that the carbon chunks may/or may not foul the sparkplugs during the cleaning process.
This cleaning process may take a little time.
A running motor can tolerate quite a bit of water spray before it runs rough or missfires. Water is a natural bi-product of combustion.
Spraying water down the carb at idle or while just reving it up in neutral , may remove some carbon but not near as much as when done while driving on the hyway at high speed or while running at WOT over time.
It will not clean the carb thou.
Car: 89 Formula 350
Engine: 409 nitrous' small block
Be prepared to spray a lot of water. The trick is to rev the motor up and then add water til it bogs. It does work though, and black chunks will come out if you've got carbon build up. I actually usually do this with some b12 chemtool. I also disconnect the exhaust before the cat to keep from damaging it.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heh, yea the misting the engine with water thing works.
ive tried it on 2 cars now... one was clogged up already, and it cleaned it pretty well... the other was just fine but i did it anyway... didnt really effect anything..
Car: 91 Camaro Vert
ambainb
Apr 25, 2016 09:21 PM
MantyZ28
23
Sep 29, 2015 11:33 AM
Dialed_In
Aug 20, 2015 01:45 PM
build, carb, carbeurator, carbon, carburator, carburetor, clean, engine, misting, motor, remove, running, spray, spraying, water
