TBI - switch - > Carb..
Old Aug 6, 2003 | 11:04 PM
nathan2003's Avatar
Car: Camaro
hey guys,, i got me a 305 TBI and wanna put a carb and new intake on it... can someone just give me a general layout of what parts i'm all going to be needing.... or what would be the best kinda carb and intake for it... i'm lookin to spend decent amount of money... not planing on going full bore though something affordable here.... i know this seems knida rediculous but i wanna get this changed and i don't know where to even start on what kinda carb i want and what kinda work i'm gettin my self into... i have a friend whos lookin for parts for me right now and i wanted to see what you guys had to say... thx
Old Aug 10, 2003 | 01:55 AM
dennis6's Avatar
Car: 1991 Camaro RS
Doing the same thing as you...
Here is most of what you need...
600 CFM carb -Holley 1460 or Edelbrock 1406
dual plane manifold
Mallory Carb bypass regulator
and some way to lock up the Torque Converter.
Old Aug 11, 2003 | 11:33 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I'd also get a good distributor with an adjustable vacuum advance
Old Aug 11, 2003 | 02:15 PM
dennis6's Avatar
Car: 1991 Camaro RS
Yep, Get an HEI vacuum advanced distributor. Forgot about that one.
Old Aug 12, 2003 | 05:29 PM
marhornetmech's Avatar
Car: '89 rs t-top/ '78 firebird/ '94 Z-28 convertible
Engine: 305 carb./ 350/ LT1
Transmission: T-5/ TH350/ T-56
i recommend the edelbrock 1405 manual choke. no future problems when choke thermostats go bad. i also recommend edelbrock performer intake (get the square bore setup or make sure you use the spreadbore to squarebore adaptor if you don't for more continuous mixture flow. I started my conversion by buying a set of hedman headers from jegs- the $100.00 variety for 82-92 f-bodies, nothing fancy. Then I deleted a/c, smog, emissions, a.i.r. injection, egr, etc. If you go with headers, wrap them first, then paint them with ceramic based high temp paint ( I didn't do this first, and had to go back and re-do it...but it made a world of difference). I already had my intake on. Then I went to the local speed shop and got my e-brock 600 carb, holley adj. fuel pressure reg., and bottom of the line somewhat performance hei distributor ( that's all you need bec ause you can always upgrade it in the future by change the weights, adding an adjustable vac. advance, etc.). Then I ordered some side pipes from j.c. whitney for exhaust (cheap, true dual, easy to hook up, no cats). Left the computer in the car, but the only thing it is controlling is the fans. She's running beautifully right now, too beautifull. now she needs a cam, but i think some 1.6 roller rockers will suffice for now. Anyway, you can do all of this in one weekend if you order what you need to order first. One last piece of advice, splurge and get the locking header bolts, and if and when you go with side pipes from j.c. whitney, go with the 58 inch pipes, and when htey asked me what car they were for I said '72 camaro (pre-emissions-no epa hassel).
Old Aug 12, 2003 | 11:38 PM
SlowMaro's Avatar
im sick of my tbi, well the ecm in general....so i can do the whole swap easily, quick question, ...how do i get the distributor to work? i mean, the wiring harness is completly different for the secondary vaccume advanced dist that i have....do they make a dist with secondary vaccum advanced for a 92 rs type wiring harness???
oops ment to post this as a new topic...sorry
Old Aug 13, 2003 | 12:24 AM
nathan2003's Avatar
Car: Camaro
hey ,, thx for all the input so far... i'll really really take all this into consideration... wanted to know a little bit more on the distributor part and headers and how much work and what percations i should be aware of while doing this... i'll be sure to keep you all posted on my progress.. and what all goes down... thx again .. hope to talk to you all soon..
Old Aug 13, 2003 | 12:42 PM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
oh vetsky id say try the power pack from ebrock with the carb, intake, cam and lifters, for about 540 bucks. If you know anybody who can do the cam for ya.
Old Aug 13, 2003 | 01:05 PM
NTChrist's Avatar
There's a tech article on this, on the main page. That should answer most of your questions.
I'm doing this swap (started it already), and I'll report back with any problems I have.
BRoss99
Aug 10, 2025 05:08 PM
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
92camaroJoe
Aug 13, 2015 06:07 AM
