stupid metering rod question
Old Aug 28, 2003 | 06:43 AM
SlowMaro's Avatar
ok i know nothing abot carbs, but i heard that with my Lt1 cam, and ported n polished heads, i should get the lil kit that edelbrock has.. which ones should i use and will this help performance????
Old Aug 29, 2003 | 03:34 PM
Damon's Avatar
Tuning is not something that you can usually say "put in the following rods and jets and it'll be perfect." Every combo wants something a little different so it's a try-it-and-see kinda situation. Start from stock calibration as a baseline and make changes to ONE THING AT A TIME and see if it helps or hurts. Take notes. You are guaranteed to fail the memory test on stuff like this. Work in small changes, methodically and MEASURE the results (like at the strip). Don't go by "seat of the pants" feel- your mind will play tricks on you.
Old Aug 29, 2003 | 06:20 PM
SlowMaro's Avatar
very very true....i need to just shell out 120 bucks and hit the dyno for an hour. i wonder if they have a stop watch type deal and let you make changes and not charge you for the time you are swapping crap.
on a different note i stuck a cut off in place of my cat that was gutted and dear ***, ...that sob is loud....i rival harleys... --leaves it open-- lmao :hail:
Old Aug 30, 2003 | 04:52 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
also check your plugs when you get to changing things because they will tell you if your heading in the right direction or not.
Cleotiz
Jan 6, 2018 08:56 PM
mantaguy
Sep 1, 2015 08:39 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
