wiring electric chocke ?
Old Sep 10, 2003 | 09:24 PM
nathan2003's Avatar
Car: Camaro
hey all just switched tbi to carb... and now i have an electric choke... does anyone who knows from past expiearances where a good 12 volt source is that is only on when the key is turned forward... don't really wanna cut wires and start testing them.... if you know where one is it would be very helpful... thx again..
Old Sep 11, 2003 | 12:43 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
There should be two spots on your fuse panel marked 'IGN' that have power only when the key is turned to 'RUN' and 'START'. Tap into one of those, and be sure to use a fuse, as those points aren't protected against overload.
Pete
Old Sep 12, 2003 | 07:29 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
The Choke heater needs power all the time that the motor is running. It is used to turn OFF the choke as the motor warms-up. You "turn on" the choke by pressing in the gas and releasing BEFORE starting the motor.
Ikes 91Z
Dec 9, 2015 03:49 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
