neeeed help
Old Sep 22, 2003 | 09:00 PM
1986camarojoe's Avatar
Car: Z28
Engine: 310
neeeed help
ok I just got done putting the new motor in I'm using a vaccum advance distributer and a holley 650. The car starts but cant stay idling on its own unless you turn the idle up but then it dies when you put it in gear. I'm not sure what the problem is i'd appreciate any help.
Thanks,
Joe
Old Sep 22, 2003 | 11:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assuming the carb and distributor are in proper working order, you probably don't have enough timing advance. Rotate the dist housing counter-clockwise a little, and see if that helps. Get a timing light on it and check w/o vacuum attached at as low an RPM as you can get it to run (800 or so), shoot for 8-12 degrees before top dead center.
Old Sep 23, 2003 | 03:28 PM
Car: Z28
Engine: 310
Yea thats exactly what I did. Is there anything else that could be causing a problem?
Old Sep 24, 2003 | 09:20 PM
Car: Z28
Engine: 310
Nothing??
Old Sep 24, 2003 | 10:33 PM
five7kid's Avatar
Give us more details about the history/condition/configuration of the carb & ignition.
Sounds like an idle circuit or ignition problem.
Old Sep 25, 2003 | 03:40 PM
Car: Z28
Engine: 310
well the carb is a holley 650 and the distributer is just some vaccum advance i found at the junkyard. My friend told me I might need to adjust the valves
Old Sep 25, 2003 | 06:18 PM
five7kid's Avatar
If that's true, there isn't much advice we could offer about the carb & distributor that would be of much value.
A JY distributor could have all sorts of issues, too. Would be helpful if it could be run on an engine that is otherwise known to be good.
Is the carb new, used, been sitting around with gas in it since 1978, recently rebuilt - what?
Old Sep 25, 2003 | 08:56 PM
Car: Z28
Engine: 310
The carb is used but I know it's good because I bought it from a friend and it always worked fine on his camaro. I put the cap and rotor on the distributer that were on my old electronic distributer they work the same right?
Old Sep 26, 2003 | 01:09 PM
five7kid's Avatar
The cap & rotor interchange. Would be nice if you could verify the distributor works on his Camaro, too.
Go over everything very carefully to make sure there isn't something not together right. Valve adjustment, spark plug wires going to correct cylinders, etc.
86TransAm350
Members Firebirds
Jun 4, 2013 05:46 PM
87cmroiroc305ho
Jan 16, 2010 01:05 AM
blimko
Sep 27, 2007 06:21 PM
burn0ut305
Members Camaros
Aug 2, 2007 11:39 PM
