carb still running rich ?
Car: Camaro
my carb is a 1406, i have a 305 1991 block, i have a problem with the carb runnin so dang rich, pressure is turned down mixture turned down still puffs black smoke and runs rich,, what is my next step to take,,, rods or whatever ???
nathan vetter
nathan vetter
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I have a 1406 Edelbrock carb. It was running slugglish because it was getting too much fuel (especially when you first pressed the gas pedal). I then changed the carb's springs & rods. This fixed my problem.
I believe the spring kit was about $16 and the rods were between $20-$30 (all from Summit). Changing these took about 10 minutes or so.
Hope this helps.
Hope this helps.
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
First of all, Where did you get the carb? Was it new? Or used?
If you can turn the air-fuel ratio screws all the way in (lightly) and it still runs, your floats are set too high or inlet valves are bad.
If it was new, Your parts man just ordered a 1406 for a SBC not taking into consideration the cu. in. of your engine, and correct application. Only place the engine can get fuel from is the idle circut or main jets. If you have the EST ignition system, check and make sure the Initial timing has been set properly (by the directions on the under hood sticker).
theshackle
Mar 5, 2017 06:37 PM
