Proform Main Bodies???????
Old Jan 10, 2004 | 03:27 AM
chad89ta's Avatar
I JUST INSTALLED THE 750 FPROFORM MAIN BODIES ON MY 650 DP,I CAN GET THE CAR TO RUN RIGHT,THE IDLE IS POOR AND WILL STALL AT A STOP THE PROFORM HAS 8 AIR BLEEDS 4 IN THE FRONT 4 IN THE BACK HOW DO THESE WORK,CAN YOU ADJUST THEM??????THEY LOOK LIKE CARB JETS
Old Jan 10, 2004 | 10:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Whoa, stop shouting already!
I assume you mean you can't get it to run right.
The air bleeds are adjusted by changing, like jets.
That probably isn't your problem, though. Are you able to make any difference by adjusting the idle mixture screws? Are you sure you got everything together right - no leaking or blocked passages? Since you have to use your old throttle plate, it's possible adjustments on it aren't correct and are causing problems, even if you didn't have "issues" with the 650.
I assume you've verified the float levels are set properly.
I found that mine idled much better when I hooked the vacuum advance to the manifold source (the timed vacuum port doesn't operate with the Proform body).
Old Jan 10, 2004 | 11:26 PM
chad89ta's Avatar
i checked everything on the floats and i just put the 650 main body back on and it still does it,so i guess its not the proform but the car ran fine till i put the proform on i dont understand it
Old Jan 13, 2004 | 09:50 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
I had the same problem with one of their billet metering blocks before.
Street Lethal
Apr 30, 2019 12:14 PM
angel2794
Sep 8, 2015 06:22 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
