Q jet issues
Old Jan 13, 2004 | 12:58 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Q jet issues
I did the stupid thing and disassembled my carb while not understanding how to label the stuff so I could put it back together.
I went to the junkyard and got one from an Oldmosbile 88 same year. The guy said the engine was a 350. I have a 305. Will that be a problem?
Old Jan 13, 2004 | 01:02 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
the fuel entry / filter are oriented straight forward in an Olds carb. The Chevrolet q-jets have it pointing to the RH side of the car. I would get a Chevy one instead.
Old Jan 13, 2004 | 01:17 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
They didn't have any from a Chevy. Is that the only problem I will have?
Old Jan 13, 2004 | 01:28 AM
jmd's Avatar
jmd
Doubt it. Their ILC & secondary vaccuum break are setup differently IIRC.
They used Chevrolet CCC Q-jets from 1980 through 1988. Look harder.
Old Jan 13, 2004 | 01:31 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I kinda see the problem as the fuel entry goes straight over the thermostat (?).
I had to replace the fuel line anyway, so can't I just bend the new one so it mates up?
And how do you keep the fuel from running out of the pump at the bottom?
Old Jan 13, 2004 | 01:45 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I looked at all the F-bodies, Caprices, Monte Carlos and trucks they had. 50% of them are TBI. The other 50% have no carb at all as someone got to them.
Old Jan 13, 2004 | 01:46 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
i ran a qjet with a forward fuel entry and added rubber hose to the fuel line to route it differently. Its a hack job but it worked just fine and absolutely leak free.
Old Jan 13, 2004 | 06:23 PM
Damon's Avatar
Make sure the throttle, kickdown cable and cruise-control (if so equipped) hookups on the carb work with your cables. Often time they won't without some work.
Old Jan 13, 2004 | 11:41 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Hey, I learned how to drive in a '73 Caprice and roll a Crown Vic everyday.
Big and fast can be very nice:lala:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
