What to do about fuel-oo(had to rythme)
Old Jan 13, 2004 | 11:46 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
ok i am going from TPI to carbed on my 88 Iroc, i am going with a single plane intake and a 650-750 Holley double pumper, about a 11:1 compression, i ma making a bracket racing/drag car hoping for mid 12's. but i read some where once(can't find it when i need it) about i dont need to take the fuel pump out and that there is a fuel pressure regulator to drop the pressure low enough so i dont need to remove the pump(i just put the damn thing in there 4 months ago) otherwise should i rip all that out and go fuel cell with a lower pump and regulator? i am trying to do this on somewhat of a budget so i dont need top of the line, but i dont want cheap carp either(snuck around that bad word ) but if some one can give me p/n or a brand or if they have a working one, but anything will do me better than i am now thanks
Old Jan 14, 2004 | 05:53 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I did the same thing and I just used a Mallory 3 port regulator. I used factory fuel lines and all. Works great, just remember to set your fuel pressure before fireing the motor.
Old Jan 14, 2004 | 07:09 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Part# 4309. Mallory three port adjustable fuel pressure regulator.
Old Jan 17, 2004 | 09:47 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Just make sure you dont go over 8 psi.
Old Jan 18, 2004 | 12:17 PM
Jester's Avatar
A stock pump can't feed a motor like that with any regulator. Do the conversion right the first time..or you will be doing it again later.
Liquid_Metal
Oct 15, 2015 03:16 PM
onebad92
Oct 30, 2012 02:32 AM
wilhay
Oct 20, 2011 02:57 PM
sr20fd3st
Carburetors
Nov 13, 2008 07:29 PM
coldasice
Nov 17, 2007 09:46 PM
