Carb swap question
Old Mar 17, 2004 | 09:37 PM
insayne's Avatar
Car: 1984 Mint Z28 H.O.
Engine: 305 H.O
Transmission: 4 Speed Auto =| gettin megashifter
Carb swap question
I just swaped out my old 305 HO for a 350, but i kept my old intake manifold. now i bought a holley and was all ready to put it on and it doesnt fit the stock manifold is there some sort of adaptor plate i can get? whats everything i need to do it and where can i get it? thanks.
Old Mar 18, 2004 | 12:27 AM
AM Racer's Avatar
You can get an adapter plate from a few sources (Mr. Gasket for 1) to go from the Rochester spread bore to the Holley square bore, but you'd be far far better off using the correct manifold.
Old Mar 18, 2004 | 07:58 AM
insayne's Avatar
Engine: 305 H.O
CC Q-jet to holley
well ill be much better off getting an adaptor plate because im poor and my q-jet is cripplin my nice new 350, so whats exactly what i need and where can i get it, my friend also said i need a fuel rail?
Old Mar 18, 2004 | 09:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your q-jet is not crippling your 350. If something isn't working right, that's a different story.
What Holley did you get? Is it new? The most common design is a dual feed type that requires a "T" or "Y" to split the fuel flow to the primary and secondary bowl. Pre-fabricated lines are available from Summit, for instance HLY-34-150 or HLY-34-160 (depending upon which type Holley you got, 4150 or 4160) for $24.
For adapters, SUM-G1401, $15.
Don't forget you need a vacuum/mechanical advance distributor. Summit has a killer deal right now for a Mallory HEI, just $133.
Of course you're going to need to adapt the throttle cable, SUM-G1414, $9. And TV cable bracket, HLY-20-95, $18. And cable studs, HLY-20-2, $10.
Don't forget a drop-base open element air cleaner, since your nifty L69 HO dual snorkel air cleaner isn't going to fit over the Holley fuel bowls, SUM-G3000 or SUM-G3001, $18.
Oh, yeah. The torque converter clutch won't lock up when you disable your ECM with this mod. BMM-70244, $160.
So, you're poor? You're going to be poorer. There may be ways to do these things for less money, but there isn't any way to do them better. To say nothing about the loss of gas mileage that will result from the Holley swap. Which reminds me, you'll need to tune this Holley, better get the 64-99 jet assortment HLY-36-181, $40 (individual size jet pairs are $5, doesn't take long to pay for this kit).
I don't know what's "crippling" your engine (you didn't give any details), but most likely changing the carb isn't the right answer.
Old Mar 18, 2004 | 10:56 AM
insayne's Avatar
Engine: 305 H.O
someone told me
someone told me my q-jet is set up for my old 305, so just putting it onto my 350 is crippling it, so how do i set the q-jet up for my 350 and is it hard to rebuild the q-jet with a kit? im the type of person who with good directions chould do anything. but theres def somin wronge, my 305 used to get on it when i floored it, now my 350 theres no knoticable difference from half throttle to full throttle, and at full throttle the acceleration goes up and down and is barly choppy but u can tell. any ideas? i just put the engine in and its slow as hell, thanks.
Old Mar 18, 2004 | 10:58 AM
insayne's Avatar
Engine: 305 H.O
duno
duno if it matters but i already swaped to a vacum distributor
Old Mar 18, 2004 | 11:35 AM
AM Racer's Avatar
At full throttle it goes up and down and is choppy?
like a misfire?
Old Mar 18, 2004 | 12:29 PM
five7kid's Avatar
Re: duno
With a computer controlled carb, there's your problem. You need the computer controlled distributor with the computer controlled carb.
If it's not a computer controlled carb, it's still not the carb type, but perhaps carb tuning. Typically, though, there isn't enough difference between a 305 & 350 to cause severe problems.
insayne's Avatar
Engine: 305 H.O
maby
chould bt, the guy who put the engine in timed it by just twisting the disctibutor till it idled right, not sure if thats the right way or if it works.
Old Mar 18, 2004 | 12:31 PM
insayne's Avatar
Engine: 305 H.O
why doesnt it work
why whouldnt it work? seemed to work pritty good on my 305
five7kid's Avatar
That's what you do until you can adjust it properly.
But, you just can't mix CC and non-CC parts.
Old Mar 18, 2004 | 12:32 PM
insayne's Avatar
Engine: 305 H.O
lota question
i have alot queistion, if u got aim please im me at insaynesicness
Old Mar 18, 2004 | 12:33 PM
insayne's Avatar
Engine: 305 H.O
so then
so then id be better off switching to my holley, i need the adaptor plate, new air cleaner and a fuel line, that whould be less then a new distirbutor
Old Mar 18, 2004 | 12:35 PM
five7kid's Avatar
The computer needs input from the distributor in order to give the carb proper instructions on mixture control. The vacuum/mechanical distributor doesn't give that information to the computer. So, the computer gives the carb default signals, also known as "limp home" mode.
So, you're limping everywhere, not just back home.
Old Mar 18, 2004 | 12:47 PM
insayne's Avatar
Engine: 305 H.O
lol
lol thats cool, i beat a pt turbo in limp mode, was gettin scared there for while, only had him by a few car lengths
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
