Vapor Lock
Old Apr 23, 2004 | 05:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Vapor Lock
For those who have endured it, what kind of fix did you come up with? I've noted electric fuel pumps, wrapping the lines as well as keeping them away from heat sources, and using spacers. Is there anything else that might help?
JamesC
Old Apr 23, 2004 | 07:45 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
keep the fuel cool.
thats about all there is to it.
Old Apr 23, 2004 | 10:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Electric pusher pump, regulator with return line, shielding from heat sources.
The factory even had a kit to add a blower to run cooling air over the carb when the engine was off and hot.
Old Apr 23, 2004 | 10:32 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
What you mentioned is basically all you can do. Running an electric pump along with a return style mechanical pump works pretty good. Just take whatever steps you can to keep the fuel cooler and that should help.
Old Apr 23, 2004 | 11:20 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I run an electric pump out back with a mechanical pump up front. I use a mallory 4309 return style regulator. I have wrapped all the fuel lines with heat wrap. Since that i am yet to experience vapor lock.
Old Apr 23, 2004 | 01:20 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Removing sharp bends can also help remove vapor lock. They act just like restrictions and create low pressure areas. The lower the pressure the easier it is for the fuel to boil.
Old Apr 25, 2004 | 06:39 AM
JamesC's Avatar
Stekman,
What electric pump are you using?
Is anyone old enough to remember putting clothes pins on the fuel line to cure the problem? What the heck was that all about?
JamesC
Old Apr 25, 2004 | 09:05 AM
TA5LiterHO's Avatar
I have heard of the clothespin deal. Forget why it was said that it helps.
I am using an external Carter electric pump out back and a new stock 3 port mechanical pump up front on mine.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
