carb psi question
Old May 19, 2004 | 08:56 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
carb psi question
okay im going from to carb and i got one of those spectre afpr and it turns the psi down but theres not return line on it will this still work or do i need to get a different one.
.o. heads 1.94int and 1.64 exh and edelbrock 650cfm carb and spreadbore intake with adapter.And full exhaust.
also what should i be running with lt1 cam 305 h
Old May 19, 2004 | 09:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get a different regulator, that has the return line. Your fuel pump won't last long running into that. It's made for a diaphragm-type electric pump, not a FI pump.
You need about 4-5 psi.
Old May 20, 2004 | 07:18 PM
tbfirebird's Avatar
Engine: ??????????
does anyone know where i can get one i aint got alot of money left so i need one that jus gets the job done dont have to be pretty jus works.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
fasteddi
Sep 2, 2015 10:29 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
