Need manifold identified
Old Jun 6, 2004 | 05:54 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
OK I got this intake manifold with a block i picked up today. both were free. I've identified the block but the numbers on the intake aren't coming up with anything. The numbers are 14007380. The closest thing i've found is this, gm #14007377
Any help would be appriciated. Also is it ok to soak it in a tub of engine degreaser, if so does it need to be diluted or can i use it straight from the jug?
Old Jun 6, 2004 | 07:07 PM
Jester's Avatar
I dunno....and not trying to be a dick but who cares man? It's a factory GM Q jet manifold...and an iron one at that. None of them are that different from any other and they all suck. No matter what it is the answer is: replace it with an aftermarket one anyway.
Old Jun 6, 2004 | 08:11 PM
Car: 1987 Trans Am
Engine: tree-fiddy
ok settles that then, I guess i will be using the edlebrock.
Old Jun 6, 2004 | 09:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a mid-late 70s smogger one; part of the 175 HP package.
Even a Performer is better. Or an aluminum 305 one. ANything, almost. It's about the worst thing ever made that has a 4-hole flange.
Old Jun 15, 2005 | 05:35 PM
rodsss's Avatar
Car: 1987 Monte CarloSS
Engine: Tweaked 305
Transmission: Tweaked 200r4
Another Mystery Intake
I have a stock aluminium CCC q-jet duel plane intake #14101074.....I can't find any record of this at GM orany of my reference books. It also has a 1.250" hole in the divider!
any comments!!!
Some aftermarket intakes have the divider machined just under the carb for better high RPM breathing. Could this be a different approach? and ....yes it could be as a result of machining the EGR!
I'm gathering the numbers from my engine build for my records.
Old Jun 15, 2005 | 07:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hole = pass-through for the machine tool that drilled the EGR
Sounds like a stock aluminum CCC piece
What more is there to say? What would you like to hear about?
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Linson
Sep 21, 2015 01:08 PM
