Leaking Gas! Help!!
Old Jun 12, 2004 | 01:20 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
Leaking Gas! Help!!
My LG4 has the stock computer carb. It's fine as long as I accelerate moderately, but if I keep the peddle floored through a couple of shifts, the idle bogs down badly (sometimes dies). If I pop the hood after it dies, there is gas dripping/streaming out of the passenger side of the carburetor, right where the choke meets the carb. Is it flooding when I floor it? Why is the gas leaking out like that? Autozone says a replacement carb is minimum $289. Please someone help me with a cheaper fix! I don't know how good I would be with a rebuild kit, opening things that have tiny springs inside scares me. I don't even like tackling drum brakes anymore. I am pretty handy with a wrench, though. Anybody else think this is a fire hazard?
Old Jun 12, 2004 | 01:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You might consider replacing the fuel pump first. It might be overpressurizing the carb needle/seat at higher RPMs.
I wouldn't say it's easier than removing and replacing the carb, but it is cheaper.
I suppose it isn't a fire hazard (yet) if you keep your foot out of it.
Old Jun 12, 2004 | 01:36 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
Now tell me if this isn't right, but aren't there two fuel pumps on this thing? The old mechanical, plus an electric close to the tank? Which should I replace first?
Old Jun 12, 2004 | 01:53 PM
five7kid's Avatar
86's didn't come with the in-tank electric from the factory. If it has one, it was added by a dealer later as part of an "anti-vaporlock kit".
The mechanical pump has a return line. There is a relief valve built into the pump that sends excess fuel back to the tank via the return line. That's what controls pressure, so I'd replace the mechanical pump first if the car has both.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
TBRays98
Sep 6, 2015 05:05 PM
tgp1990
Sep 4, 2015 06:24 AM
