Choke: Electric vs Manual?
Old Jun 12, 2004 | 09:59 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I just got my 305 short block back, and now i'm waiting on my heads and I need to get headers and my intake.
I was looking at a 1406 edelbrock, but then I saw the 1405. 1405 is manual choke where as 1406 is electric, what does it mean by electric? I saw it said "Not for computer controlled vehicles" so i'm assuming something else.
I wont have a computer at all in this thing. Also, can some one recommend a place other than summit or jegs for a good price on these units? Jegs was cheapest of the two, but I was wanting a bit cheaper.
Thanks.
Old Jun 12, 2004 | 10:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It is just that. A manual choke uses a cable and you manually open and close the choke plate. Electricity uses a 12v ign source to operate it.
Theres always eBay.
Old Jun 12, 2004 | 11:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The electric choke is automatic as well, when it's properly adjusted you can pretty much forget about it.
Old Jun 14, 2004 | 12:22 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I would recomend spending the extra $30-$40 to get an electric choke. I have had both- and I have found that the e-choke is not only much easier, but it saves gas. Once the e-choke is set properly, all it takes is 1-2 pushes on the gas, and the engine turns over and warms up perfectly. Once the engine is up to full operating temperature, once quick tap of the accelerator will drop the idle speed down to its proper level. Manual chokes can be frustrating to learn. Take it from someone who has seen both sides to the story.
Old Jun 25, 2004 | 09:25 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
the manual choke edlbrock is almost a different carb. the electric choke 1406 is a lean fuel economic carb were as the manual choke is more for performance. when i was choosing my carb for my first engine i went with the electric choke. great on gas and realy punchy down low on a 350, donno about a 305 tho.
thx
jeff
Old Jun 26, 2004 | 12:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The electric and manual choke versions are identical, except for the mechanism actuating the choke. The only differences are that the primaries on the 1405 are jetted slightly richer and the step-up spring is weaker as tuned from the factory. Who leaves their carb with the factory tune though, anyway?
Old Jun 26, 2004 | 10:07 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea i know i just refer to it like that because thats how they do on there site.but in reality they act totaly diferent as far as performance.ive used them both and at one time i had my 600 electric jetted like the manual and i still liked the manual better.. now i run a 1407 with a manual and im thinking about buying a elec choke kit because were i live we get some cold nights in summer.
thanks
jeff
Pac J
May 17, 2020 10:44 AM
bjpotter
Oct 2, 2015 09:12 AM
tattmann
Sep 27, 2015 05:20 PM
lanceflame44
Sep 25, 2015 12:28 PM
Magman
Sep 12, 2015 11:55 PM
