new pump AFPR goes nuts.
Old Jun 18, 2004 | 10:28 PM
treeohfive's Avatar
put a 140 gph pump on my car, external...i have a mallory afpr...the 80 dollar 3 port with the bypass port....
the fuel pressure now stays at a constant 9 psi....no matter where i adjust the afpr....yes its all hooked up right.
so....does the afpr tach out at 9 psi and i could be running 40 psi or some crazy s....er...nevermind
the AFPR worked fine when i had the stocker in tank pump on it.....wtf is up with this now?
Old Jun 22, 2004 | 12:44 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Did you bleed the air out of the lines like Mallory suggests in the directions?Otherwise it sounds like you are going to have to swap to a larger return line.
Old Jun 22, 2004 | 01:24 PM
treeohfive's Avatar
yeah i got it fixed, i metn to repost and say that...it took a larger return line to the fuel tank assembly....works fine now
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
RyanJB
Sep 2, 2015 01:27 PM
